- brooklyn, ny
hey guys, I recently upgraded my front brakes to the 6 piston 14.1" rotora's & now my rear brakes look extremely out of place. a rotora bbk for the rear is over $2,500, and for the most part it is more for esthetics than anything else really, I mean the front is providing at least 70% of the overall braking & unless your hard tracking I don't see the need for bbk's out back too, but, the oe rears are ugly as hell. no amount of painting them or anything will ever make them look like the belong with the front bbk's.
well, I've been researching brakes for the rear without having to spend 2.5K for just rears & I have seen that the G's & even the Z's are now swapping out the 08 G37S brakes... these are a bolt on for 07+ G's, 06 & down need a special conversion bracket for the front that a guy named zak from g35driver imports from japan, these brackets are expensive though at like $600 for just the brackets...
anyway, I'm pretty much focusing on the rears myself at this point... I do belive the fronts can be made to work with custom brackets, or you could just wait for the fx50 retrofit to become available, but i don't have the luxury of time in that my rear brakes are shot...
what I did was order a rear caliper & a rear rotor from the 08 g37s for a test fit on the fx... well, the caliper bolts right up & the rotor lines up fine as well, the only differences really are the parking brake & backing plate/ dust shield, which is smaller on the g37 than the fx.
I just ordered the parking brake/ backing plate assemblies & the remaining parts to do this rear brake swap... so I'll have a complete parts list if this winds up being sucessful, which I think it will
the g37s rear brake is a 2 piston caliper made by akobono, it looks very similar to the brembo rears on the earlier years of the z's, it uses a much larger than stock rotor at 13.8" & the caliper is pretty beefy looking, the picture showing it next to the brembo, well that's a FRONT brembo just as a comparison
all said & done, the complete rear brake setup with everything will wind up costing me around 1k... much better than the 2.5K+ that the rotora's woulda been, & now I can paint my front & rears to match without it looking retarded
performance wise I'm sure there is an improvement, but probably more in brake fading areas than stopping power to begin with... the fronts made a huge difference in stopping power...
this should be a very nice upgrade worthwhile for the guys who did a front bbk & don't want to spend a fortune matching the rears...
this is next to a brembo front....
this is the assy on a g37s...
these things are so much beefier than the oe tiny single piston rear brakes we have now...
