Bassani Exhaust
brown_fv
Premium Member
Premium
Toronto, On
Just checking in if anyone has heard of this exhaust before. i was on my350z and heard a few clips of this exhaust and i think it sounds absolutely amazing! its a true dual system but it is only made for the 350z....
here are 2 sound clips:
on a dyno
http://www.youtube.com/watch?v=GyIA9Odo6S8&feature=related
first bit is on a cold start so skip to about the 1min mark
YouTube- BASSANI Exhaust on 07 350z - VQ35HR engine
heres a picture of the exhaust piping/components so that someone maybe can tell to see if its possible to fit..
thanks
Thanks guys...
Cube, just to clarify i would have to extend the y-pipe near the beginning while it is straight before it cuts in on an angle correct? and then i would also have to extend the tips as well because of our bumper right?
this is a small project i would really like to do. i love the way this exhaust sounds, it sounds REALLY loud from the sound clips i think with my test pipes it will be ridiculous.
Sounds really nice.
On a side note - on the second video, he/she should of found a better street to do the drive by clips.....there wasn't any room for it to accelerate.
Sounds good but unless you are going the FI route at some point I think a single would be a better choice.
FI is always going to be on the backburner for me for a while but who knows.
the exhaust piping isnt as extreme as the stillen true dual. this one has 2 1/4" inlet and 2 1/2" outlet.
EDIT:
apparently they also make a version for the G35, this one has longer mid-pipes and longer pipes going to the exhaust tips
If you use the one for the G, the extender at the mid-pipe (common amongst all 350Z exhausts marketed for the G) might not allow you to get the clearance you need for the angle on the Y-pipe...
So if it's an extender PIECE like most of these exhausts have to fit the G's, then you'd simply not use it and instead use 2 extensions at the start of the Y-pipe, where it connects to the catalytic converters, aka the side that is further spread apart:
-Here---and---Here-
--------| || |------- (rough sketch :biggrin:)
^^Thanks Cube i think that makes more sense. I will probably end up ordering this when my tax return comes in. now i just have to find a muffler shop that i can find to do the custom work!
