Blox Intake Manifold Spacer
I had the blox on my car for 2 months with no problems, I have also had the skunk prior. The blox is made out of a plastic composite which seems and feels a bit cheaper than the skunks composite. I did not have any problems with it and only took it off so I could put my s/c back on.
So then you guys would recomment this? Is install hard or would I have to take it somewhere to get installed?
Easy install. Under an hour if you dont kill the bolts when you tighten down. I say for that price . . why not?
My $400- plenum does the same thing :confused:
yep . . it's a 'golden age' Crawford. It's a good plenum, & a bit of a custom look . . & it aint plastic :err:
bro, i''m unable to access that link says NOt SUFFICIENT PRIVILEAGE.
premium members can upload pictures?
Ah, now I see Jeff posted that in the support's lounge section.
Yes, you need to be a supporter to have upload privileges and access to that section of the forum.
