Brake Caliper Paint
No they dont. I used the duplicolor paint and you can just tape off the brake lines and all surronding areas to keep the paint getting on them. The kit was like $17 dollars and came with the paint brush, tape and paint. Looks good to and easy to do.
you have any pics Mrc1982 of the calipers?
I think out of thoes colors I'd stick with black or sliver....or hot pink on 1 side and green on the other :wink (2):
do the calipers need to be removed when painting them?
Threre are 2 ways to do it. If you use G2 (uses a brush), or Duplicolor (spray) you can just mask off and leave the calipers on. You will get a better outcome if you take them off, as the ENTIRE caliper will be painted. I used G2, and it came out great. I will say it is impossible to get the whole caliper (the parts behind and under), but your never going to see that anyways.
