This is the thread for comparing different ride heights and brands of springs.
FORMAT:
Car Model / Year (AWD/RWD):
Spring Brand:
Part Number:
Installed Since:
Date Measured:
Measurements:
Front
OPTIONAL: Add your alignment numbers
Alignment Numbers:
Front camber: X.X (L), X.X (R)
Rear camber: X.X (L), X.X (R)
Front toe: X.XX (L), X.XX (R)
Rear toe: X.XX (L), X.XX (R)
HOW TO MEASURE:
Please measure your drop from the center of your rim to the bottom of the fender.
Try to measure on a flat level surface.
FAQ's:
What if people have different size wheels/tires combo compared to OEM specs? wouldn't that throw off the data?
-No, because the center of the hub to the fender would stay the same.
FORMAT:
Spring Brand:
Part Number:
Installed Since:
Date Measured:
Measurements:
Front
- Driver:
- Pass:
- Driver:
- Pass:
- Fuel Level:
Alignment Numbers:
HOW TO MEASURE:
FAQ's:
