The Drop Thread (What's your drop?)
fxlr8
Staff
Administrator
This is the thread for comparing different ride heights and brands of springs.
FORMAT:
Car Model / Year (AWD/RWD):
Spring Brand:
Part Number:
Installed Since:
Date Measured:
Measurements:
Front
  • Driver:
  • Pass:
Rear
  • Driver:
  • Pass:
  • Fuel Level:
Items added or removed from the car that could affect measurements: (added.. other than stock items. i.e. Subs, Speakers, etc.) (removed.. i.e. spare, jacks, etc.)
OPTIONAL: Add your alignment numbers
Alignment Numbers:
Front camber: X.X (L), X.X (R)
Rear camber: X.X (L), X.X (R)
Front toe: X.XX (L), X.XX (R)
Rear toe: X.XX (L), X.XX (R)
HOW TO MEASURE:
Please measure your drop from the center of your rim to the bottom of the fender.
Try to measure on a flat level surface.
FAQ's:
What if people have different size wheels/tires combo compared to OEM specs? wouldn't that throw off the data?
-No, because the center of the hub to the fender would stay the same.
Car: 2005 FX35 AWD
Spring Brand: Eibach
Part Number: 6366.540
Installed Since: April 2006
Date Measured: March 6, 2008
Measurements:
Front
  • Driver: 16-9/16"
  • Pass: 16-9/16"
Rear
  • Driver: 16-7/16"
  • Pass: 16-6/16"
  • Fuel Level: 3/4 tank
Items added or removed from the car that could affect measurements: NONE
Car: 2005 FX35 RWD
Installed Since: March 2006
Measurements:
  • Front: 16-8/16"
  • Rear: 15-12/16"
  • Fuel Level: FULL
Items in the car that could affect the measurements: Spare Tire
Alignment Numbers:
Front camber: -1.2 (L), -1.3 (R)
Rear camber: -1.4 (L), -1.5 (R)
Front toe: +0.06 (L), +0.06 (R)
Rear toe: +0.17 (L), +0.16 (R)
Looks like I'm super low in the rear. Note, I have the spare in place
Lowered on Stockers & 22s
Now on coils. Need to update drop cuz it's lower :)
BC Coilovers / 10kg Front - 12kg Rear
Frnt Camber (-)1.4* / Rear Camber (-)1.8*
Lowered on GTR 20s
H&R's cut half coil front & shaved rear upper mounts
Car Model / Year: 2003 FX35 awd
Part Number: will update when I can, but correct for application
Installed Since: approx. 4 months
Date Measured: 3/6/08
Measurements:
Front
  • Driver: 16-4/16"
  • Pass: 16-4/16"
Rear
  • Driver: 16-8/16"
  • Pass: 16-8/16"
Items added or removed from the car that could affect measurements: none, spare & accessories in place, no added cargo (1/2 tank fuel)
Car: 2006 FX35 AWD
Spring Brand: H&R
Part Number: *******
Installed Since: March 2007
Date Measured: March 08, 2008
Measurements:
Front
  • Driver: 16 11/16"
  • Pass: 16 10/16"
Rear
  • Driver: 17"
  • Pass: 17"
  • Fuel Level: 1/4 Tank
Items added or removed from the car that could affect measurements: None
Car: 2005 FX45 AWD
Installed Since: September 2005
Measurements:
Front
  • Driver: 16-2/16"
  • Pass: 16-2/16"
Rear
  • Driver: 16-8/16"
  • Pass: 16-8/16"
Items added or removed from the car that could affect measurements: No spare tire or tools / 1/4 tank of gas
Car Model / Year (AWD/RWD): '07 FX35 AWD
Part Number: H&R 53043
Installed Since: March 3 2008
Date Measured: March 7 2008
Measurements:
Front
  • Driver: 16-12/16"
  • Pass: 16-13/16"
Rear
  • Driver: 16-12/16"
  • Pass: 16-12/16"
  • Fuel Level: Full
Items added or removed from the car that could affect measurements: All Stock items in place including spare tire.
got a customers in the shop right now:
Car Model / Year: bone stock 2006 awd fx35
Part Number: stock
Installed Since:oem
Date Measured:3/7/08
Measurements:
Front
  • Driver: 18-3/16"
  • Pass: 18-3/16"
Rear
  • Driver: 18"
  • Pass: 18"
  • Fuel Level: less than an 1/8th tank.
Items added or removed from the car that could affect measurements: all oem
I measeure mine from the ground to the fender. I had a hard time finding the "center of the rim" and IMO much more accurate if measure from the ground.
sorry:ehh:
Car: 2005 FX35
Spring Brand: H&R
Installed Since: April 2007
Date Measured: December 15, 2008
Measurements: from ground to fender trim
Front
  • 30 15/16
Rear
  • 31 6/16
Fuel Level: full Tank
BUMP
Would love to see some measurements from members with H&R's that have been on for awhile.
mine have been installed for almost 2 years, and a year since last measure. maybe ill re do it to see if theres any difference
305/35 22's
Car: 2005 FX45 AWD
Measurements:
Front
  • Driver: 16-2/16"
  • Pass: 16-2/16"
Rear
  • Driver: 16-8/16"
  • Pass: 16-8/16"
Hi
Is there any rubbing with your wheel/tire and spring combo during extreme cornering? Also were they able to get optimum alignment all around with this combo?
Thanx
RACER-X:iS:
