- brooklyn, ny
OK, I got a weird problem with my fx, just started about 2 weeks ago. first I noticed that when I first start the car, I would sometimes get this weird abs noise, slight, hard to explain really, kinda sounds like a wet springy noise, like what you here when abs kicks in... only does it like once & slightly... this is immediately after a cold start
then, maybe a week after this started, I start her up one day & pushed her cold through a hard u turn & my brake light came on the dash, followed a few seconds later by the slip light & the vs off light... these lights stayed on though... a little while later I shut it of & restarted & all was fine.
a few days later, the same thing.. first the brake light, then a few seconds later, the slip & vss off, since then it's been happening off & on for about a week. it doesn't do it all the time, only when she's cold. it seems to be triggered by the brake light, cause it always comes on first... the strange part is the brake light does go out after a while, once the brake light goes out, a restart clears the other 2 lights (slip & vss off) & it never comes back on again until another cold start, but if I try to restart before the brake light decides to go off, it will still come back on a restart, it's only after the brake light goes out that a restart clears the other lights...
I tried searching & didn't come up with much, one reference to something a little similar by someone who later determined it was cause his rear brakes were low & needed to be changed, but I checked my brakes & they aren't excessively low, also the brake fluid is above the minimum line... I would change all the brakes but I'm holding out cause I want to do something better than stock, & I'm not quite ready to start getting too deep $$$ there just yet....
anyone have any ideas? anyone know if brakes are included in drive train warranty, of course not the pads & rotors, but the abs & stuff? I'm out of warranty but drive train is still covered a bit longer... I hate to think of bringing it into the dealer, haven't had a chance yet to borrow a friends scanner to see if that shows anything... any ideas? I'm hoping it's not something huge like the abs pump or something...
