- South Gate, CA
- 2003 FX45 AWD
I had an incident a while back with my FX. I got to my FX and noticed that the Escutcheon was missing from the driver side door. It seems that they were trying to open the FX with a flat head screw driver.
I have seen this mod done before and with the suggestions of my peers I decided to do a write up for this simple and in-expensive mod that looks great and defers any know be criminals out there that want to break in your FX through the driver side key hole.
Here is a picture of a Stock FX Door Handle with the stock Escutcheon that has the opening for access to the driver side door lock.
I went online and got the passenger right side Escutcheon fromwww.infinitipartsusa.comfor a reasonable price.
Escutcheon # 82646 CA000
This Escutcheon will fit perfectly to cover the lock.
This is what you will need to make this mod happen:
A Torx Screwdriver
A Flat Head screw driver
And a little patience to get this done.
You will need to remove the rubber top to loosen the screw that holds down the Escutcheon.
Then use your flat head screw driver or in my case a utility knife and pop the rubber top off.
and there you go....
Now, I made the assumption that in order to remove the current Escutcheon you had to remove the bolt entirely. You wont need to remove it. You will only need to loosen it until the Escutcheon becomes loose. While you are loosening the bolt you will see and feel the Escutcheon become loose and then you can take a flat head screw driver, use a napkin to cover the screwdriver head to avoid scratching your paint, and proceed to place the screwdriver flat and pry up the Escutcheon.
Once you have take the Escutcheon off you can proceed to place the New Escutcheon. Place the left side down first and then pop in the right side. Then will come a bit of a hard part. Grab your Allen tool and start to find the groove and tighten the Escutcheon down and your done...
This is how it should look if done correctly..
The only draw back is that you will always have to have your Remote or Intelligent Key maintained with a fresh battery. I recommend you change out the battery once a year to ensure you will not have a problem.
Mod On....
A Torx Screwdriver
Mod On....
