Nismo Exhaust on FX45 Idle & Load
i think it would've been funny if you saw the FX go out of view, then someone just walked up and snagged the camera and you see the video of the ground shaking as they ran away with it.
Not exactly bolt on but close.
What you will need is to get the G35 mid-pipe extension piece and also cut and extend the tips about 7 inches. I also have an aftermarket y-pipe (not nismo) so that also makes a difference in sound. The Nismo catback comes with y-pipe and others have extended the y-pipe instead of adding the G35 extension piece to this work. You may need to add a separate hanger in the middle due to some ratteling that may occur on the FX cross brace.
+1 what Dr2k said. Since you have AWD, the transfer case will interfere with some after market Y-pipes (NISMO). So either keep stock y-pipe (Kamumei y-pipe)or get one that clears the transfer case. :top:
