Mrev 2 is compatable with out engines (FX35). Cost is somewhere around $4-500. Bolts right up. With a spacer, you should see 4-5 more hp than with just the spacer itself.
i was going by the comment on their website saying " the engine in the 350Z and G35 its the same as the engine in the FX35.. i will look more into it.. i think it would be a great mood for the fx along with the 1/2" copper iso thermal plenum spacer.. I'll see what i found out about this.. thank you much for the info!
MREV2 alone will give you comparable performance to what the plenum will give. If you get the MREV2 AND the plenum spacer, your gains from the MREV2 won't be as good as the spacer. It'll be around 3-5 hp max. Not a good performance for $400 IMO. Just get the spacer, you'll be happy..
MREV2 is just a lower manifold with the two front intake runners cut lower on top. If you're handy, you can do the same with an angle grinder.. No need to pay $400 for that thing.
thanks!
so it would be just better to just get the plenum, and not the plenum MREV2 combo.... ?
i just iinstalled an mrev2 with iso thermal copper and 5/16" spacer yesterday/today.
I started yesterday and snapped one of the 6 bolts thats inside the plenum. It snapped when I was torqing to 80 inch lbs. I actually torqued to 25 then 40, 65, 80, and then 100. Sometimes bolts just weaken after time with them expanding and contracting. The stock bolts are pretty cheap as far as tensil strength.
One way to tell tensil strength is by droping the bolt on solid concrete. A bolt with higher tensil strength will have a higher tone. The stock bolts sounded like pot metal, gave more of a thunk sound when dropped. The hardend bolt I replaced it with had a ting sound. $1.55 each, you get what you pay for
Just get plenum spacer. If you're looking for higher high rev range power, go for 1/2". If you're looking for a more balanced but slightly lower power, go for 5/16". IMO, 5/16" is a better fit for our heavy CUVs..
Alternatively, you can just get the MREV2 but why spend $400+ when you can get
the same performance @ <$200 ?
I thought the MREV2 was almost useless on non rev-up motors?
Unless he did a motor swap, no.hey HYME do you have a Rev Up engine?
hehe, well honestly I'm not sure how much it really added. I haven't been driving it for two months now because I have a probationary license right now. I can only drive to work and back home. I get dirty at work so I only drive my truck (4 banger tacoma).
Unfotunatly I got one too many speeding tickets.
I did drive it around the block onto a lonely street to test it. It felt pretty good, but like I said, not driving it for two months it's hard to tell for sure. I got four more months of driving like a grandma, it sucks!
i think the word your looking for is TENSILE
tinsel is something you put on your christmas tree
the bolt I snapped was the one that holds down the lower plenum so it was stock. Motordyne sends bolts for upper plenum since they need to be longer due to increase hight of what ever size plenum spacer you get. I also like the fact that they replace the two guid pins with bolts.
The two align just fine without guide pins.
