Infiniti EX
fxlr8
Staff
Administrator
For Release March 28, 2007
Infiniti EX Concept
Key Dimensions and Specifications
Engine/Transmission V6 engine/5-speed automatic transmission
Platform FM (Front Mid-ship) platform
Drive Configuration Front engine/all-wheel drive
Vehicle Dynamic Control (VDC) with Traction Control System
(TCS)
Suspension Subframe-mounted independent front double-wishbone
suspension with aluminum-alloy upper and lower links, highperformance
dual-flow pass shock absorbers, stabilizer bar
Independent multi-link rear suspension with aluminum-alloy
upper and lower links and axle housing, high-performance dualflow
Steering Vehicle speed-sensitive power-assisted steering system
Brakes Power-assisted front and rear vented discs with Anti-lock
Braking System (ABS) with Electronic Brake force Distribution
(EBD) and Brake Assist (BA)
Wheels/Tires 19-inch 7-spoke aluminum-alloy wheels with 245/55R19 tires
Wheelbase 112.0 inches/2800 mm
Length 185.2 inches/4630 mm
Width 72.0 inches/1800 mm
Height 63.2 inches/1575 mm
Seating Capacity 5 passengers
- 2 -
3/07
Select Technology Lane Departure Prevention (LDP) system, using a small camera
mounted behind the windshield and an advanced
microprocessing unit, utilizes the Vehicle Dynamic Control
(VDC) system to help assist the driver in maintaining lane
position if the vehicle inadvertently starts to drift out of the
lane; Around View Monitor (AVM) system with front, side and
rear-mounted cameras to help reduce the blind spots when
parking; Bluetooth? hands-free phone system
Select Exterior Features Unique liquid crystal glass roof panel that can change from
transparent to translucent; Infiniti signature double-arch grille
and dynamic arch profile; Infiniti signature L-shaped headlights
with Adaptive Front lighting System (AFS), integrated fog
lights; thin, elegant LED taillights; all-in-one sash-style side
door mirrors with integrated LED turn signals; electric outside
door handles with push switches; high-mounted rear hatchback
spoiler
Select Interior Features Driver-oriented, leather-appointed interior with luxurious
passenger space; liquid crystal glass sunroof with touch sensor
system control; Infiniti signature ?double-wave? instrument
panel and Infiniti-signature analog clock; high contrast
instrumentation with aluminum-alloy bezel surround; electric
soft-touch shifter system, designed for an artistic, jewel-like
appearance; aluminum-alloy door-side finishers and speaker
finish; oversize front and rear seat headrests with indirect
lighting; special ambient mood lighting throughout the cabin;
large-sized high-touch leather-appointed center console;
aluminum-alloy rear cargo area finisher with integrated luggage
rails​
Why would it come out as an EX25 and EX35 when the 35 engine is slowly being phased out? Why wouldn't it be an EX37? Will Infiniti/Nissan be keeping the 3.5L motor for such cars like this and the Maxima/Altima, etc.?
I sure as heck hope the FX doesn't keep the 3.5 when the 3.7 will be where the speed craze moves.
Opinions? Insight? I can imagine the EX being a sort of race wagon because it'll be lighter than the FX, not as light as the 350Z/G35, but a definite sleeper.
Also, now that they're moving to the 3.7L motor, 350Z and G35 names won't make sense. I've heard G37 but nothing about 370Z?
I think the 3.5 will be around for a while. Maxima, Altima, Murano all use the same block. Heads, cams, and adaptive timing will continue to evolve.
Okay, how about the auto tranny? Being a 2.5L, obviously a more economy version, why wouldn't they offer a manual? It would also do well for the 3.5L sportier version.
I hate to say it, but I like the EX a lot. I've been driving a G sedan for the past 4 days and I am hooked on the speed an nimble handling. The EX should be a little closer to G performance while in an updated FX body. Sounds like a good combination.
Now we know, the EX is an EX35 and the FX is a 35. As if i came from the future or something.:rofl:
