95maxrider
- 2007 Infiniti FX35 AWD
- Name
- Nick
I think I'm going to disable the "intelligent" (stupid) alternator charging system on my 2011 FX50, but I wanted to run it by everyone here in case they have any insight.
The intelligent charging isn't explicitly spelled out anywhere from what I can find, but the general consensus of how it generally operates on other Infinitis/Nissans is that the ECU tells the alternator when and how much to charge, as opposed to letting it just charge all the time, in an effort to improve fuel economy. Some people say that the system won't turn on the alternator until you've driven 8 miles. You can probably see how this could be a problem if you don't regularly drive more than 8 miles. There is also a voltage sensor on the battery negative cable that feeds info to the ECU. It's not clear if the ECU will tell the alternator to charge if voltage drops below a certain level (I would think that it would) or if it's really all down to driving more than 8 miles.
Here's a thread on the Armada forum discussing the issue:
Smart Alternator ???
And here's a video of a guy showing how to disable the dumb charging feature:
Here's info from the FSM for my 2011 FX50:
So, just like as shown in the video above, the wire that needs to be disconnected is pin #76, the only difference for our cars is that instead of it being a yellow wire, our wire is either purple for the 5.0 cars, or violet for the VQ cars.
Since I don't care about taking a 0.001 MPG hit from having the alternator run all the time like it should, I think I'm going to try this out. I just can't figure out if I actually need to pull the wire from #76, or if I can just unplug the sensor from the battery ground cable. What do you think?
