Just before the end of last year, I noticed the AFS warning light flashing a couple of minutes after driving off on a short local trip. Then the TPMS light came on too, also flashing. I continued to my destination and turned off the engine for a few minutes.
When I restarted the car the two lights were still there and the satnav screen said 'Please wait' for 3 or 4 minutes then 'SECURE' on a green rectangle. Nothing else on the centre console seemed to work; no radio/cd, heating controls etc. Heat/ a/c seems to still work but on the setting it was on when turned off.
I immediately checked the tyres but all were at 33psi.
Shortly thereafter the AFS light stopped coming on at all but TPMS always solid.
Since then I've driven about 500 miles and found that if you just hit the start button first without your foot on the brake and wait a few seconds then the satnav screen initialises properly and you can then put your foot on the brake and hit the button again to start the engine. Then the radio and satnav work for that journey. Nothing much else works on the centre console but the car drives and stops as normal. I'm not sure the Adaptive Front Lighting System is working though so that may be part of the problem.
Infiniti are no longer trading in Europe/UK so i took it to my independent (honda specialist) to check the codes.
There were quite a few and all seemed to point to a Body Control Module (BCM) issue so i bought a NOS item on e-bay and they fitted it and had it resync'd to the keys. Unfortunately, that made no difference to the problem.
There are a few Nissan dealers designated as Infiniti service specialists but my preference would be to go to an independent first and see if they can diagnose. One I have contacted said it would help if I could find service manuals/wiring diagrams online (even LHD).
Does anyone on here have anything they could share?
Google found
Infiniti QX70 (S51) - Service Manual, Repair Manual
but does anyone know if they are legit or a scam to get $10.
I will upload photos of the error codes later in case that helps anyone advise.
Google found
