Please help
thefx_35
St. Maarten
2004 FX35
Rakeem
Hello everyone..
I have a 2004 fx35, my left turn signal doesn’t light up on my dash nor do the indicator lights work when I switch it on to go left nor do the fog lights work, and my A.C controls aren’t working.
When I turn the hazards on, all lights are working fine.
My A.C still works but is stuck on auto and outside air. Radio controls work fine. I’ve check all the fuses and everything is good.
Change the multifunction light switch didn’t fix anything. So I changed the A.C module under the radio display screen and that didn’t solve anything neither.
I’m wondering if I should just sell this car for parts or is this something that can be fixed?? Does anyone else have or had this problem???
Sorry about the noise, that’s the A.C blowing.
Hello welcome to :iS2:
For the turn signal, I'm suspecting it may be the clock spring is going bad. Use this DIY for reference on how to remove the clock spring.
2003 - 2008 Paddle Shifter Installation
Hey thanks for the input but the turn signal switch doesn’t run through the clock spring. Instead, there are wires thatrun on the back of clockspring unit itself, then through the windshield wiper switch, then out to wherever it goes. I’ve already dissembled and checked for continuity and there isn’t a broken link going to the windshield wiper switch. I suspected that it was the module under the radio display because I disconnected that unit and the turn signals didn’t work at all. I’ve also checked if the connectors at the BCM are loose and all is fine.
