Transfer Case leak at electric connection
jimnivy
Texas
2008 FX45 AWD
Jim
Hoping someone can help me with a transfer case leak issue.
I was noticing that my car would buck at around 15mph, usually just after shifting into second gear. I first checked the transmission fluid. It was full, and nice and pink. I searched for a potential cause, and found posts about abs check, and disengagement of front wheels around that speed. Anyway, since I have 122k miles on it, and don't know the service history prior to 110k miles, I decided to change the transfer case and differential fluids. The case was damp (has been leaking), and the fluid badly burnt. Only 20 oz, or so came out, but the plug didn't have much grime on/in it. Refilled with a little over a quart of fresh fluid. Test-drove, and the buck was barely noticeable. It was gone with the drive to work the next day.
Now, a week later, the buck is back. The transfer case is wet, and a couple drops on the driveway. Expected front or rear seals to be the source, but both are dry. Once I was able to get far enough underneath, it appears to be leaking from around the electrical connection, right above the fill plug. The electrical connector is loose, and can jiggle/twist around a bit in the housing. Searching the service manual, I see that there is an o-ring seal on the inside of it, and a clip outside holds it in place. Anybody else dealt with a leak at this location? It appears that in order to change the o-ring, the transfer case has to be removed and disassembled. If it's the connector plastic is broken, I'm probably screwed, since it's part of the coupling assembly, which is discontinued.
I really don't want to pull the transfer case unless I absolutely must, so any advise is greatly appreciated.IMG_20211026_192642.jpg
I really don't want to pull the transfer case unless I absolutely must, so any advise is greatly appreciated.View attachment 606931
The Transfer case is easy to come out - the rear drive shaft has to come off,then the transmission/transfer case assy cross member, then the 10 bolts holding it to the transmission. The front drive shaft will slide out of the transfer case while you're pulling out the transfer case off of the gearbox.
Now, your issue, the shuttering, is most probably due to wornout clutch pack and this is the bigger issue - I think the leak came after, as a result of the temperature, burnt fluid. In this case, I don't think it will be cost effective to even open the transfer case - there is plenty of transfer cases on ebay motors that are garanteed to work and cost anywhere from $150 to $500.
Hope that helps!
Vladimir,
That is a good point. I had not thought about the cause and effect being the temperature to have caused the leak.
Friday night I cleaned the connector, and area around it real well with degreaser. Use some oil resistant RTV to seal it up and let it cure until Sunday morning.
It's nice and smooth when it's cold. After driving on the highway for an hour or so, the shutter is back. Right around 12 to 15 mile an hour after coming to a stop.
Thanks for the pointers on removing the transfer case. I ordered one from eBay, like you suggested.
I will follow up after I receive the transfer case, and get a chance to install it. Thanks so much for your help.
