2004 FX45 Intermittently Won't Crank
Sam Preston
2004 FX45 AWD
Sam
So my FX45 had an intermittent starting issue for a while now. It’ll start right up whenever I first turn it on that day, but then won’t start at all after a few short trips. It won’t crank at all, almost like the starter is bad. But the weird thing is that it will start again roughly 30 minutes later without any hesitation.
The starter that came on the car when I bought it had died completely about two months ago, so I changed that out for a second hand starter. That worked fine, but that introduced the intermittent starting issues. Some days I could go three of four small journeys without having it refuse to start, other times I could only make it one journey. About a week ago it would refuse to start at all, but I was able to get it running for another five days or so by hitting the starter whilst somebody turned the key, I did this up until Monday when my remanufactured starter arrived.
Now this new starter should work great, all of the internal components are new and it has a warranty, so I’m not worried about getting it replaced if there’s a problem, but after three starters I’m thinking there has to be something else to it. What could be causing this?
This new starter is also giving me the same problems, it’ll start in the morning no problem and will let me restart it again after one or two journeys, but then won’t start again for quite a while. Hitting it also doesn’t seem to have any affect.
The battery is two months old, and is very strong, it’s not a better problem. The wires looked just fine when I was replacing the starter, so I don’t believe it’s a wiring issue, at least not the wires directly connected to the starter. What else could it be?
I had a similar issue earlier this week and later found out the negative battery clamp was loose. After tightening, the issue was resolved. Seems you have power though, so try pressing harder on the brake pedal while starting. Got me a few times, then the vehicle started after I applied more force to the brake.
I’ll take some sandpaper to my terminal posts and battery cables tomorrow morning to see if this helps. I’ll also sand and clean the area where the negative cable connects to the body of the car too just to cover my bases.
The FX doesn’t need the brake applied to start the car, but I usually drive stick so I hold the brake when starting anyway bu force of habit. I’ll try pressing harder to see if it helps, but I doubt it seeing as it doesn’t need it on the first place.
WOW! 343k? nice! sorry I can't help with your issue.....
I’m in Canada so it’s in KM’s, but still 213,500 miles isn’t anything to sniff at!
I bought it at the beginning of the year with already high mileage, I’ve only added 5k or so to it so far (I would add more if it would start more often!), but it was the cheapest FX45 within about 500kms of me! Maybe even further, I didn’t actually check. Looking to hit 400k soon enough!
LOL! Aah...ok, still pretty impressive, there was one guy on here that was at 300k+ miles that I recall. Hope you get it worked out, one thing I can tell you from personal experience, its' definitely not the AC amp starting problem many people like me have experienced, good luck!
