x2lacrosse
My power liftgate stopped working today; was hoping to check the fuse but the fuse cover doesn't specify which one it is. Anyone know?
The FSM, likely. Not the plain old Owner Manual though. I found another thread (1G FX) that said to check the 15A fuse near the fuse puller; didn't see one near it so I checked and re-seated every 15A fuse in the box.it's in the manual I bet..
I'm having the same problem. Which fuse did you reset after disconnecting your battery for five minutes?Finally fixed. Think you have to disconnect the battery (for at least 5 min.) AND then re-seat this fuse. My tailgate now works using all buttons.
I’ve looked at as many fuses as I could find, and they all “looked” good. Does anyone have any ideas about what could be wrong??I recently blew the fuse when I tried to open the hatch after a sub-zero overnight; frozen shut. It is not explicit in the manual and I used an on-line fuse box diagram
(Infiniti QX70 (S51, 2008 - 2017) - fuse box diagram - Auto Genius) and replaced the 30 amp, pink, low profile fuse. The top of the fuse box does show which fuse is for the "Automatic Back Door Control Unit" and according to the document is listed as "Q".
One 50 degree day, some Lexol rubber/vinyl protection on the gasket, a new fuse and hopefully the problem will not happen again.
Do you mean that 15amp fuse under the hood, the larger square, pink one?The fuse I replaced also appeared to be intact but I changed it anyway; that did the trick. I figured it was worth a $5.30 investment. Whether it was actually the fuse or the resulting power interruption to that circuit causing a reset I couldn't say; easier than disconnecting the battery.
OK, thanks!Modern fuses have two small contacts that can be used for testing with an ohmmeter without removing the fuse. Never just look at a fuse or a light bulb. Test them with a multimeter. Put the meter in "diode check" mode and listen for the beep. If no beep, check again, still no beep, replace the fuse (or bulb).
Are you squared away now? It's not as evident in my pic as I thought; look closely and you'll see a red square and arrow indicating the fuse I reset.OK, thanks!
I’m going to purchase a new fuse as a last resort and see what happens.Are you squared away now? It's not as evident in my pic as I thought; look closely and you'll see a red square and arrow indicating the fuse I reset.
