Alignment after lowering
FAULKY FAULK
NORMAL, IL
2016 QX70 AWD
DOUG
I recently lowered my ‘16 qx70 using H & R Springs, plus added 20mm spacers. All good, and loving the ride. However, need some input on whether the new alignment read outs are good or if I need to add camber adapters to bring all three readings into green. Don’t want to risk promoting poss of oversteer. Here is current alignment readings:
LF: camber -1.4, caster +3.5, toe +.12
RF: camber -1.4, caster+3.6, toe +.13......front total toe +.24, steer ahead -.01
LR: camber -2.0, toe +.22
RF: camber -2.2, toe +.23.........rear total toe +.45
Hey Doug, recently added H&R's. Alignment was out enough that it would've ate my new tires and I couldnt have that so I got with Ed@tunerstore and he hooked me up with front and rear control arms which got it to factory spec's easily. Heres' one pic:
Got any specs and brand on those control arms you installed on the fronts and rears from tunerstore?
No specs, sorry but I had the work completed at the Infiniti dealership. The master tech is a friend of mine and he said the control arms worked out perfectly.
So the fronts are Godspeed and the rears are Megan Racing. Megan Racing is on back order for the fronts and have been for a while.
This was just after install at the dealership
  • Like
Reactions: gto
Here’s what I found for the control arms you mentioned. Look familiar? Godspeed red fronts, Megan blue rears. BTW- nice pic of your QX70!
So I need to buy a camber kit, I ate through my first set of tires not having the wheels aligned. So I'm on Megan Racings site, but I see they have the front camber kit in stock. How is the Godspeed by comparison?Infiniti QX70S.jpg
  • Like
Reactions: gto
The Godspeed is of the same quality as the Megan Racing. I made the mistake of trying to order from another website but please do yourself a favor and get with Ed here on the forum. He’ll save you a lot of money and time waiting. And he knows exactly what to order.
Oh and I've seen you ride on the forum and man it's badass!!!!
Ed@tunerstore
Thank you.
