I like your posts and it looks like it's getting cleaned up. PITA though although it must be nice to have a lift.
& like the look of the factory 20s, but they are heavy. R35 wheel with bigger tire, I'm 15lbs less a corner.
You mentioned you autoX. In what? & lets see some detail on the modded I30? Those were cool
Thanks! Yeah, a lift is a life saver, makes things so much easier. I like the factory 20s too, I just wish they weren't quite so heavy. I wanted a square set of R35 front wheels, which apparently weigh 26 pounds each, so only 5 pounds lighter, although they are 1.5" wider. Unfortunately, they were going to be more than double the cost of these wheels, and the wife didn't like them. Since this is her vehicle, I had to defer to her preferences.
I've mostly run auto-x in my I30, but the M3 has also seen some. But the M3 is mostly set up and used for rally-x. But I do want to make the FX so it can technically do SCCA events in case the wife wants to go. In stock form the height/width ratio is off a bit, so you either need to lower it a bit or widen the track. I plan on doing both.
I've had my I30 since 2003, it's a 1996. I just put together an updated mod list for its build thread on Maxima.org, so here you go:
Engine/Trans
-2002/03 Maxima 3.5 motor, no SS IM mod
-K&N filter, velocity stack
-2001/02 Pathfinder 70mm TB
-Custom PFTB adapter and throttle cable bracket from sicivic89
-Custom PFTB IACV block off plate from sicivic89
-NWP thermal intake manifold spacers
-NWP Block off plate
-Oil catch can
-Nistune ECU, 7k RPM rev-limit
-Cattman headers
-OEM cat
-2.5” resonated b-pipe
-Cattman muffler
-Aeromotive adjustable fuel pressure regulator
-Quaife differential in rebuilt/refreshed transmission
-Spare Nissan re-manufactured VLSD transmission that had gears and shifting mechanisms deburred, shot peened, and cryo treated, roughly 15k miles from new
-2000/01 DE-K Maxima OEM clutch and flywheel
-Poly shifter bushing
-97-99 Maxima shifter with 1” cut out from center and welded back together
-Sola Luna weighted aluminum shift knob
-Custom aluminum radiator brackets
-Put down 210 whp on old DE-K motor, about 250 whp on 3.5
Suspension
-BC Racing coilovers 9k front, 8k rear and valved to match dampers
-2.5* camber front (maxed out camber bolts), custom 4.7* caster (up from 2.2* stock, drilled new holes in front strut towers, rotated coilovers 90*), 0.1* toe out
-Corner balanced, 60.0% F, 40.0% R, 50/50 left to right
-3,130 lbs w/full tank of gas, empty trunk, full interior
-2J Racing converted the Scott-Russel linkage to a panhard rod rear suspension
-New panhard rod from Speedway Motors with PTFE-lined rod ends
-Progress RSB at max stiff
-Energy Suspension poly bushings for sway bar frame mounts (7.5118G), sway bar end links (9.8106G), control arms (7.3111G), cross member (7.1116G), and F&R motor mounts (7.1114G)
-Poly side/trans mounts
-Delrin front subframe bushings/collars
-Super Pro poly rear trailing arm bushings
-Moog control arms (better welds than stock)
Current Alignment:
-2.4* camber
+4.7* caster
-0.10* toe out
Brakes
-Wilwood 4 piston front calipers with 12.9” 2-piece rotors w/Wilwood Polymatrix E pads
-Fastbrakes 12.3” rear BBK (redrilled Accord rotors) with stock calipers and Carbotech AX-6 pads
-Track pads are Carbotech XP-8
-SS lines
-ATE DOT-4 fluid
Chassis
-Warpspeed Stage 1+2 Subframe connectors (welded)
-Custom fender braces, welded to chassis
-Stillen RSTB (Stillen front won't fit over 3.5 IM)
-No sunroof (stock)
-97-99 Maxima SE steering rack, B15 SE-R rack on shelf
-NWP engine torque link (not currently in use)
-Aluminum steering column bushing
-Relocated battery to trunk, 0-gauge wire
-95 Maxima aluminum front bumper support (-30 lbs)
-Rolled front fenders, rolled and slightly pulled rear fenders
Cooling
-Mishimoto radiator w/19 psi cap, Toyota red coolant
-Racer Parts Wholesale 24 row oil cooler with -10 AN lines
-Derale power steering cooler
Other Fluids
-Motul 8100 X-cess 5w-40 engine oil
-Amsoil 75w-90 MT fluid
Exterior
-The Retrofit Source FX-R 3” V3 projectors w/ 4.3k HID bulbs in Cefiro headlights with E55 shrouds
-TRS Blazer fog light projectors, 3k HID bulbs, independent fog light rewire mod
-All front lighting housings blacked out
-Painted grille vertical slats black
-Removed three vertical bars from lower bumper grille, filled, sanded, painted
-350Z horns
-Garage door front lip
-Nissan Murano windshield washer nozzles
-Black OEM mirrors
-35% tint
-All chrome window trim blacked out (temporarily removed)
-I30t spoiler
-Debadged trunk
-1998/99 I30 tail lights (heated up with heat gun, pressed center section together to fix common leak issue)
-All original paint (except spoiler and some touch up work on bumpers)
Interior
-Recaro Speed seat w/gray alcantara center section, CG Lock for seat belt
-Gunmetal aluminum dash trim from Shadow (old Org member), matching aluminum lower door panels
-Stock light gray leather (less than 5% of A32s?)
-Sparco L505 steering wheel
-350Z aluminum pedals, dead pedal
-Custom gray alcantara door panels
-Matching gray alcantara shift boots w/black stitching by Redline Goods
-Redline Goods black leather arm rest with some extra foam cushion inside
-Techtom MDM-100 (Set to display speed and water temp since the smaller steering wheel cuts off view of 20-120 mph)
-95/96 Maxima SE gauge cluster, gunmetal aluminum gauge rings
-Innovate Motorsports LC-2 Wideband O2 Sensor
-Innovate Motorsports MTX-D Oil Pressure & Oil Temperature Gauge
-99 I30 Limited aluminum door sill/scuff plates
-Most interior lights are white LEDs (Gauge cluster, door switches, HVAC display)
-97-99 Maxima center console with flip-over cup holder
-Fuzzy pillars (stock)
-Replaced cracking chrome interior door handles
Stereo
-Pioneer DEH-80PRS head unit (5V pre-out)
-Focal P165V15 6.5” component front speakers
-Hertz DCX 165 co-axial rear speakers
-Carstereoadapters.com PVC custom speaker adapters
-12” JL W6 subwoofer, Sonic Electronix 1.15 ft3 sealed box
-Boston Acoustics GT2 (125w RMS x 2 for front speakers) with 4 AWG OFC wire
-Alpine MRP-M500 (500w x 1 for sub) with 4 AWG OFC wire
-Clifford RS3.5 alarm with remote start
-MDF trunk floor with bracket to hold sub box in place
-14 AWG oxygen-free copper (OFC) speaker wire to speakers
-12 AWG oxygen-free copper (OFC) speaker wire to sub
-E-Dead sound deadening in the trunk, front doors and rear deck
-Frost King insulation in the front doors and other areas
-E-Dead sound deadening on front fender liners
Wheels/tires
-17x8 Enkei RPM2 +45? with 245/45/17 Michelin Pilot Super Sports
-17x8.5 Enkei RPF1 +40 with 245/40/17 Hoosier A6
-ARP extended wheel studs
-2J Racing 10mm front, 15mm rear wheel spacers
It will soon be receiving an HLSD 6MT out of a newer Maxima as well as a motor from an 09+ Maxima. I'm hoping to get it to around 300 whp when it's all said and done. Here are a few pics:
It's my baby!
