Were you able to keep the parking brake by bolting the rear caliper to the 1st gen knuckle and using the fx50 rotors? I thought that was the reason Turbocad did all the research and created the adapters for the 2nd gen knuckles as the parking brake could not otherwise be retained?
I think I’ve seen some other folks ask in this thread and the original Turbocad thread but does anyone still have the pdf with the full write up for the rear calipers? Or the one from this thread, as the link in the 1st post appears to be dead.
Also, I bought my own 2nd gen rear knuckles way back when I first stumbled across this great mod, and the knuckles came with the 2nd gen hub assemblies, parking cables and backing plates already attached, only the included backing plates still need to be bent/cut. Does this mean that I can mount the 2nd gen knuckles with the 2nd gen hubs already attached, with turbocad’s adapter only, in my 2006 fx35 and put on the FX50 rotors? Or will perhaps my gen 1 axles not fit the newer hub or parking cables not be compatible with my car? I thought all 4 corners were direct bolt on for 2nd gen 2009+ FXs so that’s why I got curious. Thanks a bunch to everyone who’s worked so hard on this mod!
