Ashephillis
I will start off by saying i have been a mechanic on the side for about 18 years and have tons of experience fixing all kinds of vehicles, so Here's my latest dilemma. I removed my intake tubes to install new plugs and in the process i noticed my throttles were a bit filthy, so i gentlymoved the throttle plates open by hand and cleaned them with intake cleaner and a soft brush. Afterwards car was idling high, i figured id need to do an idle air relearn. No big deal, I have a snap on verus pro (10k scan tool) with the latest software. No luck, test will no complete tired over 50 times. Ok, so i try the "pedal dance" those of you not familiar that is the manual way to do the throttle relearn, with a series of key on, key off procedures. No luck there either, tried probably 50 times.
I gave up and took it to the dealer, they couldn't even do the relearn with the consult 3 dealer software. So i came to terms with the fact i damaged my throttles, dealer quoted me about $1300 for them. So i sourced a used pair inline for $240, install them, annnnnd nothing. Still high idle, around 1200rpms , still will not relearn for anything. I know certain conditions have to be met for the test to complete, and all have been within spec.
At this point i dont know what to do, there is a chance that the used throttles i got are no good but its slim. I dont know if i should pony up 1300 for new oems or what. Maybe the ecm is fried? The car drives fine at speeds over 40, but stop and go traffic is not good.
This is bad when even the dealer is stumped. I refuse to let them just start throwing parts at it to try to fix it. Any ideas?
