Peak Long Life
FX35 - Coolant?
Good read. Thanks for sharing.
I'm concerned about this because I recently had to replace my water pump. When I saw the condition of the water pump it looked horrible, caked on build up of something along the periphery, corrosion, etc. I believe the previous owner did not use the right coolant in the system and it attributed to it's condition. So i want to be certain to use the right coolant going forward.
So after more researching I think the different colors represent various additives that are present or not present in each type. The factory coolant doesn't contain amines or silicates which may harm water pump seals nor borates that may cause aluminum corrosion and pitting.
blue color lacks: amines, silicates, borates
green color lacks: amines, silicates, borates; contains "advanced formula" EG based product
So any alternative should avoid those additives right? I actually bought some Beck Arnley recently when my fx35 was low on coolant. I was hesitant, but decided to do so after I read the label and did a quick search on my phone to see that it was compatible. So today I read
more info about it and see that indeed it is a good choice:
Formulated For: Acura, Honda, Infiniti, Mazda, Nissan, Scion, Subaru, and Suzuki.
- Provides superior extended life corrosion and rust protection
- Utilizes Phosphated Organic Acid Technology also known as Hybrid Organic Acid Technology (HOAT)
- Contains no amines or borates and is free of silicates
Also see attached SDS's for the BA & Nissan OEM coolants.
