What did you buy for your FX / QX70 today?
Thanks. I would have thought that 285 was too narrow. Thanks for clarifying!
It is a lot of stretch but strictly because it is a show car. Usually people run 325/30 on a 12 and 285/35 on 10.5 . I’m doing a staggered 22x10.5 / 22x12 so equal stretch all around but smaller diameter tire in front to get rid of the front being higher than the rear
Finally had to replace the VLED Triton V3 Running Lights from years ago. One was starting to die and producing a lot of heat. Got a set of the new TritonV6 to replace. We'll see how they go.
Replaced my old and used KiDO coil overs with a brand new set of BC coil overs that I snatch off eBay for $450.
KiDO coil overs are going straight to a metal scrapping facility along with the old OEM struts.
First oil change w/ Mobil 1 full synthetic and cilajet protection inside and out.
Are you using anything for camber issues? If so, what and are you using them on both front and rear?
Installed Q60 shift knob. Definite improvement over original! Still have to match stitching with sharpie. Other than that I’m satisfied with this reasonably low cost improvement.
Installed 21” gloss black wheels wrapped in 295/40/21 Continental Control Contact tires (Thanks to this forum for all of the tire information, helped immensely in picking out the final tire size).
I’ll be selling the stock 20” wheels with 7/32” tread tires are Goodyear Fortera should last 70k miles, they have about 15-20k miles. If anyone has any suggestions on what these wheels are worth with tires please chime in.
16F101A1-45FC-4164-B632-3539A55BB258.jpeg 6A53CA81-F637-46D2-AD76-EA1DA86CC174.jpeg 50176D01-5C15-4269-8A2B-77CDD647AF04.jpeg 06BE0139-6909-4C9E-B3B2-4CDF5F93D369.jpeg 242292EE-069D-43F4-A006-EC000652E763.jpeg
Installed the Cusco strut bar!
Cleaned out the intake manifold and throttle body while I was at it. What a difference!
