Interior Back Lighting not working
jwh25
San Diego, CA
2010 FX35 2017 QX80
The back lighting behind all the interior lettering is not working. Possible fuse blown? I see there is an interior and exterior fuse box, which one should I be looking in and which fuse should I be looking at? Thanks! 2010 FX35.
Are you talking about the kick panels? Standard have no lighting... Are you sure you have the upgraded ones with lighting?
No, on the steering wheel, all the buttons on the console and the buttons for the navigation. They no longer light up.
Yeah... That should be a fuse... Does your manual have a list of fuse locations? Hopefully it'll be an easy spot within the cabin (the 1st Gen had 3 fuse boxes, with 2 being in the engine compartment and 1 nearly inaccessible unless you took your battery out...)
I have a similar issue but my door light are the only thing that do turn on. Dome, Push button start, peddle lights nothing works. I had LED's there before but not nothing works? What can this be? I don't see any burnt fuse.
