Adebolu Ololade
- 2006 FX 35
- Name
- Adebolu
My name is Adebolu Ololade. I ride a 2006 Infiniti FX 35. I suddenly experienced a drop in acceleration with 'Service Engine Soon' flashing intermittently.
Is the engine hesitating on idle? like if it's going to shut down?
Sounds like a cylinder miss-fire. Usually a spark plug or coil pack failing. This happens due to age of the parts or oil in your spark plug wells. You should inspect the wells, if you find oil, your valve covers are leaking and need to be replaced.
Get the error codes to be sure.
