onthemove
I installed two of those little door lock actuator replacement kits from ebay and did the pass front & driver rear. They work well. I noticed some issues inside the panels, noisy little noise makers that have been driving me nutz. I fixed the noises on all 4 doors.
The driver's door will not open from the outside. Doesn't matter if it's locked or not. It will open from the inside. I did not replace the actuator, all I did was remove the panel, tighten bolt's, tape plugs and wires to the panel, etc. and then put the panel back on.
Did this two days ago. It all seemed fine until today when I used the key in the lock to drop the windows down. Weird shit with these damn imports. They've got gremlins for sure. What am I, the fucking dukes of hazard now? Rant...rant...bitch...moan...complain...rant, shit!
There are two cables that attach to the inside handle. After detaching both of them, the one with a ball on the end sticks a little but does go in and out. The other moves in and out but not as much as it should. This is a mechanical issue for sure. Anyone out there experience this before?
