What did you buy for your FX / QX70 today?
Went in for an oil change and was supposed to get the dealer to do a balance, alaignment and tire rotation for $139 which was basically the price of another dealer so they were price matching it a savings of $100. However they did not record doing it bc the tires only have a few months left which I’m actually looking for right now, not sure if I’m going to do winter tires or all season. I in turn ended up getting the battery replaced bc the reading were low and it was the original one. He knocked off $30 from the battery.
Upper seat cushion for my 1st gen since the old one was trashed! & the notorious height motors that always fail.
Just delivered. I was told these are the replacement parts for the gates racing blue belts.
Killer deal at pep boys for these great oem plugs. FYI, There’s a code on site you can plug in . Cheaper than amazon. I just picked up a set and going in tomorrow with the new belts. Can’t wait. Plugs always make the motor feel new again
The deal for first gen plugs only?
2nd Gen is a different plug, but the pricing is 30% off already decent price on all NGKs
This is OEM part:
Belts easy and fit. Plugs on pass side a bitch. Found oil too, so gonna need infamous 1st gen valve cover job. Guess it’s just time at 12+ years
Some I purchased some led bulbs for the headlights. I replaced the bulbs and noticed that when I turn on the turn signals the turn signal flashes like crazy. I also noticed when I put the hazard lights on they flash normal. Is that a normal thing?
It's the resistance in the LED's... Your car thinks the front turn signal bulbs are burnt out...
Only problem is you won't know when your turn lights burn out since the load resistor will "trick" your car to always thinking the bulbs are there and working fine...
