skagen6675
Any of our vendors sell Akebono BBK? Thinking about purchasing a kit in a few weeks. I found this kit. https://conceptzperformance.com/Car...23&Car_Type=G37&UID=2012122116211866.249.73.5
For the rears, yeah you need a special knuckle kit for it to fit... turbocad6 made a bunch and sold them all... I think he actually put the specs up so anyone could have it made, but you'll need to go to a custom CNC machinist to have it done...
Brakeing is okey with front bbk but front pads useing too fast with oem rear . (Rear oem caliper & pad is weak and don't have a chance to use anymore)
All job doing the fronts, I know that, but they consume too fast . I'm using oem new pads form qx70 2017 breaking is great, after 7000 I must buy a new front pads. In this set rear oem pads has forever lifetimeWhat front pads are you using?
Changing your rears will do nothing to help your front wear. Nearly all of your stopping is done by the fronts.
Bigger brakes on rear is not even needed IMO. Rear OEM caliper and upgraded pad actually work quite well. I've only changed my fronts and have no wear issue . . with heavy brake use.
