dragonh
- 2005 FX35 AWD
Hi all, 3 weeks ago, my oem alternator went..While testing, it read 12.2, then blew out a coil with a puff of black smoke..Changed the huge electric harness with the coil but OEM alternators here run 1,400 USD so my buddy got me a new aftermarket one for 150 USD..That lasted 2 days..stated up..Voltage was 13.8(normal) drove for about 45 mins,,parked in an outside carpark..Tried to start it again after I turned off the ignition as I had to back up a little more...Wouldnt start..All lights on the dashboard were flashing like crazy..Had to get it towed to the shop...Alternaror was not charging the battery..2nd replacement alternator was put it..They kept it at the shop for 4 days, checking voltage and,temp as well as mountain driving and road driving..All ok..So I thought! Drove yesterday..voltage was 13.7/8 but after driving for a couple of hours,and on the way home..Volyage dropped to 12.5 and water temp went up as well.
Seems that when I drive up a small mountain road or the car gets hot, voltage drops..All coolant in the tanks are normal! Wires were checked after the 2nd aftermarket alternator was put it..(No shorts)..As I am Stillen SC with more power, MUST/SHOULD I get an OEM alternator?
Any suggestions on what it could be or what else I can check..Thanks all
