Thanks! Is the intake pretty good? I heard there aren't any good options for intake?Stillen Gen3 intakes off of a G37 if your willing to do a little cutting and fiddling around and definitely a tune. Through Uprev you can adjust shift line pressure and get faster shifting, however the delay between moving the shifter/paddle and the shift is nit affected... But overall faster shifting
Light pulley and cat back if you are aiming for more power, cat delete u already made. Search for air manifold upgrade with some manifold spacer if you ll not gona to go with FD and stay NA [emoji48]
Thanks! What intake manifold would you suggest? Also, the video is sick! Which twin turbo system are you using?I had the 2nd Gen long tube stillen, it was gd, I was able to go 55 AWHP up to 295 AWHP on Mustang Dyno, 10% more on Dynojet reading.
Now with Twin turbo I went to 420 AWHP on 7 psi and soon will be tuned again on 11-14 psi.[emoji48]
Thanks for sending the pic. Do you have close ups of where you cut into the radiator support?Yeah the Stillen Gen 3 intakes are probably the best ones for the VQs. They come out in front of the radiator and get cold air that goes into the front grille. But theyre made for the G37/ 370z so you have to remove the bumper and cut holes into the radiator support...View attachment 393537
Is it the MREV2?for NA you might think of motordyne if am not mistaken.
Is it the MREV2?
Saudi Arabia.....You will gain top end with the 3.7 VHR or Z1 upper plenum upgrade... If you put your car on the dyno you will see a dip in power about 1k rpm before redline. The intake plenum upgrade will help with that but to be completely honest, you wont really feel the difference. Get a good tuner and you wont be disappointed. There are many Uprev tuners in the US. I'm not sure where you're located but I know a few in California that do email tunes as well.
Saudi Arabia.....
