Terron Cleveland
- 2003 FX35 AWD
- Name
- Terron
Folks, need some advice what brand and size spacers I should go with for front and back wheels, I have Vossens CV3r 22"
Will need the width and offset of the rims too...
That's just the size of your tires. 22" is the diameter of the rim. If you want to suggestions on how your set up will look, you need to tell us the WIDTH of the rims as well as the OFFSET...265/40/22
No... Read my post again...So you suggest 15mm front and back?
You could run a 25mm spacer and probably be fine without rolling the rear fenders. I used to run a 22x10.5" rear +25 with a 285 tire and no fender mods - that was ~30mm more aggressive than you are now with no rubbing. A 265 tire buys you a little more room. I only had to roll the rear fender and trim the plastic when I switched to a 305 tire. In the front, I ran a 9" wheel and 265 tire at a +5 offset which is 33 mm more aggressive than you have now. It rubbed slightly but I ran coilovers and the car was adjusted all the way down.
I currently run 20x10.5" wheels and 275/40 tires with +5 offset in front and +0 in rear. Rear fenders rolled and plastic cut, no mods in front. Other than adjusting camber to -2 front -3 rear, no other work was done. It only rubs when I bottom out. There's a lot more room in the wheel wells than people think. Spacers are cheap, just buy a few sets and try them out - I have 15, 20, 25, 35mm spacers that I've picked up and swap in and out. Without knowing ride height and camber, it's all just a guess as to what you need. But to be conservative, you'd be fine with a 15mm like some recommend. You'd also probably be fine at 25mm but it's not guaranteed, you may rub.
This is how far out you can push the tire without much rubbing (w/ fender rolled). It's 57mm further out than your current setup so 2.25". The look isn't for everyone, but it's a reference point.
