Dyno FX37/QX70
veritas
Los Angeles 818/213
2015 QX70 2013 FX37 2011 FX35
3 pulls for $90 on a Dynojet so might as well.. Car is completely stock except for a test pipe but (left side test pipe gasket is cracked). A Ford RS with bolt ons running 24psi had went on the dyno right before me and the FX made more power lol. For some reason the guy said there was some electrical interference so he couldn't get the torque??..
Cool
2WD?
Without a rpm measurement, the dyno can't determine torque. Electrical interference was probably messing up the tach signal. Dynojet uses a fixed weight roller so it can measure how fast your car accelerates the roller which is the hp. Without rpm, it can't determine torque since hp is just torque x 5252.
