What do you guys think - if I want to replace the rear turn signal/brake light bulbs and the rear side marker bulbs, which VLEDS would you go for? I want to do a red bulb mainly because that is what their site suggests for red lenses. And would I need load resistors for your brake/turn signal suggestions?
Thanks bro!
I actually noticed that the Lumen's claim to not need load resistors. I'm going to call them today and find out definitively.
Ah ha, gotcha - thanks so much!The above quoted load resistors are for the CAN Bus systems. They do not prevent hyper flash like in our FX. You will need good old fashion load resistors.
I should probably order an interior panel removal tool, right? I've always had trouble in the past breaking fasteners when removing panels. Any suggestions?
