Pathfinder Cooling Mod
dragonh
Taiwan
2005 FX35 AWD
Hi guys, Has anyone installed the Pathfinder Cooling Mod on the FX?
Also would it fit if you are using the Stillen Blower?
Pics enclosed.
Any info: kindly let me know.
Tks
Haven't heard of anyone done it here. What's the benefit?
This kit contains all of the OEM Nissan parts required to complete the "Pathfinder" Cooling Mod on VQ35 engines. The addition of a rear coolant crossover allows for better, more even engine cooling, and bettercoolant flow across both banks of the engine. Keep your temps low even when pushing the car hard!!
The Nissan Rear Coolant Bypass Modification Kit allows coolant flow to the rear cylinders, and dramatically lower water temperature by 20 degrees. Installation is a direct bolt on to the engine, but the original pipe that connects to the upgrade pipes to be modified to use a straight coupler.
Reviews:
