H&R Lowering Springs
BjLiveFX35
FX35 AWD
B
Is anyone here running these H&R springs on their Fx? I'm thinking about getting them because I want my Fx lower but nothing dramatic... anyone have pics of how much lower it'll actually be??
I had them a long, long time ago. Ride is fine, not that different from stock. But I ended up swapping to coilovers - I'd recommend just going there first. Many people start off with springs and then swap.
If you do get H&Rs, I'd recommend cutting the front so the drop is even. I cut 1/2 coil off and it doesn't impact anything, the spring rate doesn't change and it still seats fine. You can do a search but it's pretty common. If you don't cut, the rear will be a little lower.
