MY 2011 INFINITI FX50S steering wheel, audio rotary button, FX50 brake change color, 22-inch wheels,
Curious if you ever used the FRONT SS brake lines from StopTech....I couldnt get mine to fit correctly when I did my BBK upgrade...
Just curious, what didn't fit? Length? Or banjo bolt?
And very nice car OP. It's good to see people still doing more than just basic mods.
Bolts were too long front & rear. I bought the shorter bolts from Concept Z Performance.
The length of the Front hoses was the problem. I cold not figure out a good routing of them without them rubbing or binding when turning the wheel at full travel. Was not comfortable with them. Kept the front stock 3 piece lines in place.
The rears fit no problem....
What is your rear dashcam plugged into? Looks like, with the hatch cover off, it is plugged into a socket. I am deciding on the dual channel setup I want, and that caught my eye.
Thanks!
Photo for reference:
How do you like these for beam pattern/distance/effectiveness? Looks like you have the LaminX installed, since these are 5500k, how yellow are they - they look green on the truck in front of you.
Thanks.
Beam pattern: 80/100
/ Distance: 65/100
/ Effectiveness: 70/100
Yes I have already installed LaminX
It seems to be green
Do not understand what you mean!
It looks like the cable is plugged into a port, where the red light is. Did you install something to plug the camera into, or just run the wire from the front windshield, and it just looks like there is a jack to plug into there?
Would like some info on the cross drilled and slotted rotors shown where you are painting the calipers green a couple of pages back. Wondering what brand they are? Thanks in advance!
