Throttle body screw size
carl292
Odessa
Fx35
Hey guys. Replacing the bank 2 cam sensorand i need to take off the throttle body. That bottom right side is a b***h and i think i am close to stripping it. Using a 5mm allen too. Any ideas on size sa i can ru up to ace?
All four are the same size, just take one of those came out with you to your local hardware store. ;)
I am having the hardest time for the lenght and size. Dealer doesnt know either.... Damn looked everywhere. Dealer only has one
I don't know what you are asking the screw is an M6 (6mm) and it is 45mm long. The thread pitch is 1.00.
That is literally all the information you need to purchase new bolts for this item.
If you are talking about the shoulder of the bolt, just ignore it, buy one which has threads all the way down to the head.
^^ What he said. If you go to a hardware store and get a 45mm long M6 bolt with a 1.00 thread pitch, it will fit. Don't worry about the allen head size because an M6 will only come in one size.
If you're that concerned, just pop your hood in the parking lot, remove the screw and take it in... Probably faster than what you're doing now.
Just a FYI, wrong on the length part.
Haven't had time the go back to ace, gotta wait til this weekend. I'll post it up. I was able to use pb blaster on the bottom screw and it came out but the hex head it all messed up, so i still need to get a good one.
