Window Issue
Falcon73
I pulled my 09 FX35 out of the garage and left it there for about 2 hours. When I came outside to leave, the driver's window was down about 2 inches (it was fully closed when I pulled it out). Now the driver's window won't go up or down. All other window switches on the driver's door work fine. Also, the driver's door won't lock from the outside (remote or outside lock button on the doors). The door lock button on the driver's door works fine.
Any ideas?
I've disconnected the battery - no luck. I guess I'm going to pull the drivers door panel to see if the switch has come unplugged. Not sure about any of this.
This happened to me......Once they peeled of the door panel, they found that the steel wire was corroded, and hung up...they replaced the whole assenmbly.
yea mine was like this. i replaced the regulator and that was the issue for me. i dont know about the door lock issue though.
If you have both window and door lock issues at the same time i would check the harness between the door and fender. Everytime you open & close the door it bends. MIght have a loose connection there or a broken wire. Kinda rare on a vehicle that early tho. Unless the door has been opened and closed a gazzillion times!
