will these wheels fit ?
sonar
2009 FX35
Shopping for wheels for the summer, looking at some concave wheels in 20". Trying to stay in 20" to not sacrifice the ride comfort. found these awesome Vossen wheels on ebay, they come in
(F) 20x9 +15mm
(R) 20x10.5 +20mm
will this fit on stock suspension?
those are going to stick out a little bit...if you lower the car it will rub big time and youll have to camber the rear wheels, or get really short tires. Either way, the size is ok but the offset seems a little to aggressive... mine are +25 rear +45 front and the rears are flush and the front are flush with a 15mm spacer....
your going for staggered im guessing. I dont know how that would look on the FX with the vosswn but they do look good with the G37's. I would say go same all around you'd be good. 20x10 as far as drop goes unless your on coilovers you have no worries depending on tire size. If on springs you should be fine with what your going with.
---------- Post added at 04:29 PM ---------- Previous post was at 04:27 PM ----------
Hey bro I was about to buy this same vossen wheel and they told me I can go with the new 22"x9 for all 4 wheels, by 10" on the back wont fit they are going to be poping out... So they told me 22"x9" is best
Know , if you go the route of running 9" wheels on all four, the fronts are all flat while the rears are concave. Someone here has these in 22's which looked great with the full width rears. Check the wheel gallery I believe.
the 1st gen right?
---------- Post added at 09:09 AM ---------- Previous post was at 09:01 AM ----------
hmmm i run 24"x10" and its a perfect fit no sticking out.:smug:
i see you got pre 09 FX. Is the 1st and 2nd gen FX the same? as far as wheels go, if u can be flush with +25 R + 30 F on your 1st gen, am i gonna be flush with my 2nd gen?
Im scared that 22" will hurt the ride too much. I changed to 18" for winter and felt noticable improve in ride comfort from the stock 20"
They told u that 9" width is best, but with what offset?
