Gendaito
- Portland, OR
My jackstands are 2 1/4 ton. Will they be strong enough to hold up my '04 FX35 without squishing me like a grape? Anyone else use 2 1/4 ton jackstands?
So the weight rating is per jackstand, not combined? So a single 2 1/4 ton jackstand can hold up 4500 lbs?
thanks for the replies. I have four of these jackstands, all rated at 2 1/4 tons. I was going to use all four at the same time (one per corner obviously), and put them at the factory-specified jack points.
So the weight rating is per jackstand, not combined? So a single 2 1/4 ton jackstand can hold up 4500 lbs? I never understood the weight ratings of jackstands.
Good times when your car falls down (better times when you are not under it). Where do you place your jack stands Ed? My stands have tall V notches that render them partially worthless with the FX.
lol...when a car drops on you once, it makes an impression
