Which FUSE, REAR Outter Tailight Corners Out
Did you tab into any interior light for power to trigger some recent mods in the center console? If so, that's the problem. I have had this happens to me. The second I wire it up turn on the car, and the taillights fuse blown immediately.
well, crap, i got another problem... so, i blew the fuse again (i think by hitting hazard lights button) so I put new 10A fuse. To make sure all the connections are good, i took center console (the one with cup holder and gear shifter out), checked all the connections, put it back in. Now I am putting the clock back in, and when I insert the clock connector into clock, my hazard lights come on.... and stay on.... can't turn them off... button is useless... only way to cut it off, unhook clock.... what do I do now?
Wow your FX is just taking you for a ride with the electrical issues. So is the button busted? When you push it does it seem like it's not doing anything?
My guess that if you unplug the wire from the button housing the lights should go off, but you won't be able to use the hazard function until u wether try to fix the button or get another one.
I'll look at mine later, it could be as simple as stuck spring mechanism.
At least seems like you took care of the blown fuse issue. :-/
Yeah, just disconnect the connector on the back of the hazard switch/button for now. Most likely it just stuck and you probably put a bit to much force on it while pushing the center console back in. Take the switch out and play with it to see if it binds on the console opening.
