Where to find the fuse for both fog lights?
kwang
New Jersey
I had HID fog lights installed on my FX35(Driver side has the 6000k from the PILOT kit I got 5 years ago, and the passenger side were replaced from a cheap $40 kit I bought several month ago). Both fog lights went out at the same time last Thursday while I was out driving the whole day(with rain pouring). From my experience, the bulbs usually do not burned out or the HID ballasts do not went out at the same time. I am guessing if there's a fuse for fog lights that burned out which I can simply replace it. I hate to order another HID kit, spend time replace the HID kit then turned out it is something related to the fuse or wire harness....
I opened the fuse box by the battery area under the hood and also opened the fuse box by the e-brake. But both fuse charts do not show a fuse for fog lights or even head lights. Call the dealership and they have no idea...
If anyone can help will be greatly appreciated.
Thank you.
On my 2007, the fog fuse is located in the fuse box behind the battery. You actually need to not only take the cover, but also the plastic housing that covers the passengers side of the windshield. Behind the battery there is a conical shaped plastic piece that can be removed and house the fog fuses.
