Wheel adapters to convert 5 lug to 6?
Mynes09
Jersey
Ok guys a friend of mine has a set of 2011 22" qx56 rims for sale.can I run these if I get a set of 5 to 6 lug wheel adapter?I'm worried about the rims sticking out of the wheel well...
Thread moved to the proper section.
Can you post the specs of the qx rims? Offset? 22x?
QX Wheel specs are 22x8 30et. Motorsport tech has a 5 to 6 conversion, minimum thickness is 35mm. This will make the qx rims have a -5mm offset which will position the rims 45mm outwards from the stock fx rim position.
From Motorsport Tech:
Wheel Adapter Configuration - Complete!
2005 INFINITI FX35_-_FX45
Your Bolt Pattern: 5x114.3mm
Your Hub Diameter: 66.1mm
Type: Two Piece Adapter
Hub Centric to Car & Wheel Centric to Wheel
Number of Studs: 6
Thickness: 35mm
Stud Size: 12x1.25
Center Bore: 77.8mm
Diameter: 6 by 139.7 (5.5 inches)
Quantity: 4
The price for the above configuration (before tax and shipping) is $360.00. Tax and shipping will be included in your total on the Payment Configuration page.
and from our handy dandy offset calculator:
