It will read higher. Someone want to do the math?
Found this:
[FONT=Arial,Helvetica,sans-serif]This is why we recommend people use a rough percentage adjustment to estimate flywheel hp on the Dynojet versus a rough fixed adjustment on the Dynapack. In our experience, a manual transmission FWD car will lose 20-25 hp to the hubs on the Dynapack. A RWD car will lose 25-30 hp and an AWD car about 35-40 hp (the FWD case has been verified on an engine dyno). In contrast, losses on the Dynojet will be in the 12-14% range for FWD and 14-16% for RWD (opinions vary).[/FONT]
[FONT=Arial,Helvetica,sans-serif] [/FONT][FONT=Arial,Helvetica,sans-serif] [/FONT]
[FONT=Arial,Helvetica,sans-serif] [/FONT][FONT=Arial,Helvetica,sans-serif]Let's work through a comparative example for the same car on a Dynapack and Dynojet.[/FONT]
[FONT=Arial,Helvetica,sans-serif] [/FONT][FONT=Arial,Helvetica,sans-serif]Car A produces 205 hp to the hubs on the Dynapack. This would equate to between 225-230 hp at the flywheel. The same car produces 195 hp to the rollers on a Dynojet. This would equate to 222-226 hp at the flywheel. Furthermore, the difference in power matches up very well with our calculated difference due to inertial losses. And interestingly enough, we have tested just such a car on our Dynapack and a Dynojet back to back with the same results (actually 196 vs. 206 hp).[/FONT]
[FONT=Arial,Helvetica,sans-serif] [/FONT][FONT=Arial,Helvetica,sans-serif]Let us then assume that we modify Car A to produce 25 hp more at the flywheel (maybe a good head port and set of camshafts). The car would now produce almost 230 hub hp on the Dynapack, but on the Dynojet it would produce 217.5 hp. Same car, but the difference between the two dynos has grown from 10 to 12.5 hp, largely due to inertial effects.[/FONT]
[FONT=Arial,Helvetica,sans-serif] [/FONT][FONT=Arial,Helvetica,sans-serif]Please keep in mind that these are rough approximations based upon some loose physics and real world experiences. But they should provide a better insight into the difference between loaded and inertial dynos, and hub vs. roller dynos, along with assisting the user in trying to compare results across the different systems.[/FONT]
