update on ride
Nice, did you adjust the rears or is that the driveway? if so, did you lower the shock and rear spring together? Still need to do my rears, and trim my mudflaps.
Thanks i had black tis wheels with the stainless lip n the perception of the wheels looked small. There is a very minimum wheel gap ill take some pics on a level surface as well. I was going to do the door handles soon. I did the rears, whatever you drop in the shock you do to the spring. I just think the no lip wheels look bigger.
nice, wheel specs and tire size?
How are your outer control arms and tie rods doing? The ball joints at a pretty severe angle?
Also, did you have to put it at a firm setting going that low?
Overall, nice job. I like how the rivets are inside the wheel well.
honestly the bc setting are not that high no where how hard they can be I think they are set somewhere between 10 to 16 from soft, main reason was because of that gt spec rear brace that sits soo low but now im good ride is still smooth with the drop.
giovanna dalar 5
22 by 9 offset 38 but i have the HR spacers that put me around 18 on the offset.
I wanted the 10.5 wide wheels but they said that they wouldn't fit the fronts and i didn't want to stagger the wheels. 265 35 22 pirelli scorpions awesome year round tire had them for almost 3 years eventhough I have taken them off for the winter they are holding up pretty good. with the way the bc's are shipped from the factory i can set them pretty soft but of course the lower you go you need to firm them up so you do not rub. I am working on some new pics on a leveled surface, sometime during the weekend if the pacific northwest weather holds up.
