U-Turn Loose Rear End
DaChoZn1
Houston, TX
Hello All,
I have a 2006 FX35 2WD with about 97K miles on the odometer. I recently installed BC Coilovers and 20mm spacers all around using factory O.E. 20" wheels.
Here's my question,
I noticed whenever I have to make a hard left U-turn, my rear ends feels loose. It feels like Right Rear wheel breaks loose. Almost like the wheel is not bolted on tightly or my rear tire is flat. This issued existed before and after the BC Coilovers. I was hoping that the coilover would help resolve this issue. No luck
Any idea what it could be? It's driving my nuts. I'd appreciate any information or suggestions you guys may have. Thank you in advance.
Couple of things that will help, rear sway bar will help allot with body roll. Gt spec rear lateral brace to tighten up the chasis. Keeping your tires around 36-38 psi will help a just a bit.
