Typical Maintenance 95K
lowKut
Queens, NY
Hey folks my FX35 is soon approaching 95K mileage range and I could use some suggestion on some typical maintenance which should be done on the FX35 at this point.
I plan on getting the truck re-painted hopefully sometime after winter, but wanted to address all the mechanical aspect first.
The following services was performed:
• Dealer Services: Replaced front L/T front outer tie rod set TOE 17-C8D4B. Mileage: 83374.
• Dealer Services: Replaced Power steering pump Auth 17-C8D4B. Mileage: 83374.
• Dealer Services: Replaced L/T front wheel bearing AUTH 08-P5KDO. Mileage 83768.
• Dealer Services: Valve cover gaskets, STAB, SRT UT, Shocks, Tie rod, Belts, Wiper, LOF, Alignment. Mileage 84429.
• Replaced gear shifter. Mileage 85995.
• Replaced Alternator Belt, Ac Belt, Change spark plugs, AC / Engine belt. Mileage: 88155.
• Replaced fuel sender unit. Mileage: 92,704
Regards,
Mark
did any of those go bad for you to replace them? some of them arent maintenance stuff more of a wear and tear. Hopefully it was covered on some type of extended warranty
Just curious, what did each of those services cost you?
Did you do most of the 30k interval major stuff at 90k?
I bought the vehicle with approximately 84K miles. Previous services which was performed was done on behalf of the previous owner which I was able to obtain those records from Infiniti.
Other than what is noted I am not certain what other services was performed such as 30K interval etc...
The only thing I paid for was the plugs, belts and fuel sender unit which is typical cost most stealer would charge for parts/labor.
[TABLE="width: 111"]
[TR]
[TD="class: xl63, width: 111, align: right"][/TD]
[/TR]
[/TABLE]
