yeah man, iforged 3 piece, specs like chedman said... iforged offers a lot of different designs that can be had in this configuration, just pick your center design & request these specs or alter offset to your liking & depending on your overall final ride height... front lip is 3", rear is 4". the only set of tires that I found to work perfect in this combo with the awd is the yokohama advan st... a sport truck ultra high performance summer tire. even though guys will always yell at me for calling the fx a truck, it still is a good idea to use a sport truck tire for the heavier loads this thing can generate....
this wheel combo is one inch less overall diameter than stock, 29.5" vs stock size of 30.5" overall diameter... front tire is 265/35-22" & rear tire is 315/30-22"
this has a few effects, slightly taller gear ratio for slightly better acceleration, 1/2" lower to the ground & 1/2" add'll clearance to the wheelwells & suspension if you lower it low... slightly less mpg due to the slightly taller overall gear ratio... speedo will be slightly off to, like it wasn't before?
Iforged are pretty good wheels but there overall finish & final machining & polishing details is a bit lacking if you compare them to real top of the line wheels like HRE or asanti's or something... I winded up having to refinish the wheels myself out of the box to make them as perfect as I'd want them to be.
I just picked up a set of HRE's for my minivan & wow, what a difference.... the finish work is just about perfect even on the inner edges of the wheel, pefection that iforged just doesn't give you out of the box at all, out of the box they look better than even the iforged after hours of sanding & smoothing roughly finished machine marks & edges... depends how anal you are & how much you're going to care about these details...
