Transmission Fluid Question
MTN FX
Mountain Man
Premium
Big Bear City,Ca.
2004 FX35 AWD
John Green
So I ordered some ATF for my 04 FX35 AWD and wound up ordering Nissan Matic-S.
Below is the info that was shown on the site I purchased from. It states that Matic-S supersedes Matic-J.
My question is will the Matic-S be ok to mix with the Matic-J that's in it now?
"The exact Original Equipment Manufacturer fluid that your vehicle came with; use where Nissan Matic-S fluids are required in Nissan, Infiniti, and other make vehicles
Matic-S ATF supersedes Matic-J ATF
For "Rear Wheel Drive" 5-speed automatic transmissions (that is 350Z, Armada, Titan, G35, FX35, FX45, M45, Q45)
Not for Nissan 3 or 4-speed automatic, front wheel drive 5-speed automatic or CVT transmissions"
you can mix them. you well not be able to remove all the matic-j out the trany. i did it and and my trany is doing fine.
