Dynamo
- Austin, TX
Why does something that should be easy to do always end up being more complicated that it should be? The service manual is somewhat confusing and seems to say two different things.
When checking the fluid level the dipstick goes in reversed so the mounting tab is opposite of the mounting bracket, correct?
Does the dipstick get pushed down all the way into the fill pipe or just to the point where the bottom of the plastic handle touches the top of the fill pipe?
When checking mine, if I push it all the way in I can't get a good reading. The fluid level goes way up on the dipstick and I can't really tell where it stops. If I were to go by that method it would seem that it is way overfilled.
However, if I just push the dipstick down only until the bottom of the plastic handle touches the top of the fill tube then fluid level clearly appears, and happens to be right at the top of the hash-marked hot fill range. This method makes it so the dipstick sticks about 20mm further out of the fill tube than when it is secured by the bolt.
It seems strange to me that you wouldn't push the dipstick all the way in to check the fluid level but yet that method yields a perfect and clear reading. If I push the dipstick all the way to check the level then I can't get a clear reading.
The service manual says to insert it all the way in but then the next sentence says "to check A/T fluid level, insert the A/T fluid level guage until the cap contacts the end of the A/T fluid charging pipe" which kind of sounds like not all the way in. Anyone know for sure?
